performance suggestions
supra_fast
FN Fast
May 13, 2006
128
Calgary, Alberta, Canada
i have an 88 supra turbo. bone stock except aftermarket rad. i have like 3500 to spend on it and i want all GO. i dont know a whole lot about performace. like i said i want as much go as possible without risk of killing my car. the cheaper the better so i can go farther with the 3500. leave me your suggestions and where i should buy from.
suprastore any good? are there prices good? or should i go somewere else
thanks for you imput
americanjebus
Mr. Evergreen
wa.
if you havent already, HEADGASKET. do it right, hell pull your engine buy a toyota gasket set, replace as much as you can, get your block smooth as hell at your local machine shop, get your head machined and put it back together with arp's and prefferably with a metal head gasket, cometic or hks. (you said you wanted all go so your safer doing this)
Change every fluid with that money, everything that can possibly be dripped out of your car should be changed now that you can so you dont break something expensive while your worrying with having lots of GO. A well lubed drivetrain will help allot.
AFTER that.
Read these.
http://www.supramania.com/forums/showthread.php?t=16
http://www.supramania.com/forums/showthread.php?t=17
http://www.supramania.com/forums/showthread.php?t=1103
as far as purchasing, hoarsepower freaks, Becauseican, and Cooleeze are on my trustworthy list.
Boss302
249
Mobile, Al
supra store is slow. thats all, jscspeed.com is really good done buisness with them a few times radiator, fan, guages very prompt delivery and fast to give you a TRACKING# and receipt oh if you can help it use paypal as much as possible as your method of payment it's alot more secure and leaves a better paper trail and the supplier never gets your finacial info it's just transfered out of you account into theres
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Suprastore is not bad in my eyes. I ordered an hks super dragger back in the day from them, shipped promptly and arrived in about 3 days to me in Ottawa Canada. Shipping was fair, all prices were fair. Infact hpf is the one screwing me on shipping most of all anyway. Shop where your parts are dude.
eric
supraman7mgte
Shut up,bitch!!
Sunny California
as far as making more ho to go fsater,get a full 3 inch exhaust with a down pipe depending on your smog laws.
K&N FIPK or a HKS intake system.
new intercooler and piping.
new plugs and performance wires.
aftermarket bigger radiator.
water temp,oil temp turbo psi gauges.
replace clutch fan.
Adjuster
Get your car into the 400's at the wheels :)
Few ways to do it and be reliable and fast at the same time, and NOT spend all of your 3k.
Buy my used bolt on Turbo, 550's and Lexus meter. IT works fine on the stock TCCS, but you will need to buy a areomotive adjustable fuel pressure regulator. (Sold on here by a few folks, and they are worth every penny.)
Get yourself a good wideband to tune with.
(Shameless sales pitch, but really it would be a good upgrade path for him at this time. Live with 420rwhp for a few years, and then if you think you need more, buy a larger turbo and go the route I'm on now shooting for the 600+mark.)
Your going to need brakes and other stuff before you head out for 600however :) (If you want to come home alive that is.)
My turbo would run you about 2k if you buy a new one. Fuel will run you 300 for the injectors or more, and the Lexus is 150 used at the salvage yard with a sensor. All you need after that is a DP which will be EASY using the parts I'm including with the turbo setup. (It has the flange and a short pipe, you just add your DP to it, or make one, or have one made, and then choose the cat back exhaust of your choice. )
Put a Walbro pump in the tank, and your good to go. :)
So, 1000 for the turbo
275 for the injectors
100 for the Lexus.
450 for the cat back from your choice of sources.
95 for the Walbro. (Again from the many sources out there.)
250 for a Areomotive AFPR setup.
Remove the J tube, do some simple mods and your pushing 420 at the wheels on pump gas man, and have some money left over for larger sway bars, wheels/tires/brakes and other fun stuff like springs and struts.
Sorry in advance for the shameless plug for the stuff I'm selling, but you asked for the low cost way to do it, and I'm offering an option. :)
