people with turbonetics bolt on turbos
gixxer750
2jzget comingsoon!
Mississippi
what did it take to put it on in the way of oil, coolant lines? Whatabout mounting the wastegate actuator....
Has anyone used this turbo with the bic ddp? I've got a 62-1 on the way but hpfreaks can't tell me what I need to get it hooked up.
I hope this turbo is worth it since I've been waiting over 3 months for it.
outofstep
Senior Member
fwb
I have that exact turbo, but on an external gate. I'll take some pictures to help you out, but I gotta roll to work so It'll be tomorrow. For the coolant lines, just use the stock location that would normaly feed the CT26.
I hope you have a spacer, if not you wont be able to mount it. The comp cover is too big.
Jspec7m88
1,583
Nappy City
62-1 is one bad butt Turbo. :) I promise, as long as you have the rest of the car up to date and healthy, you won't be upset with that Turbo.:biglaugh:
gixxer750
2jzget comingsoon!
Mississippi
Well, I've got a built engine: Wiseco pistons, shot peened/destressed balance and weight matched stock rods with arp bolt, polished crankshaft, block decked, head surfaced, cometic 2.0mm head gasket, ARP head studs, ARP main studs, New oil pump with ported housing, B&M oil cooler with thermostat(full flow), Custom 2.5 inch hardpipes, Going to have maftpro, custom intake hardpipe, UR cam gears, greddy timing belt, ported head and manifolds, AFPR, BIC DDP, Koyo Radiator, TRD 180 deg thermostat, custom 3.5 inch exhaust.
I would say the rest of my car is up to date :) The new engine has 950 miles on it. I do have a spacer....
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Which w/b did you get?
