people in CT holla!
gmoney
supra is as stupid does!
Apr 22, 2005
97
CT
home1.myspace.com
whats up people i need someone with alot of expierience with the 7mgte, mine is dead and im swapping it out either this winter or early spring and i need someone in ct that wouldnt mind making a small drive to help me out. If you work for beer and food and the love of cars your my guy if you need a little bit of cash i can work with ya, if you require as much as a mechanic thanks for your time thus far.So pm me and let me know what yall can do thanks.
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
I would be more than happy to help you with your 7m. I am currently working on mine and it would have been done along time ago, but I keep upgrading and winter is coming so I don't really need her anyway. I am not an expert, but I have a lot of experience with cars and I will do my best to help you out. I wouldn't want money, beer is fine:icon_razz Letme know when you are planning on working on your car. I am at school right now, but I come home as often as I can get work off so if you give me a heads up then I should def. be able to make it. Hopefuly more people want to help because I need someone to tune my car perfect when it is all done!
Jon Martens
ps-sorry I never got those wheels, I splurged on a rebuilt head, pnp with cams and now I am looking for wider wheels..maybe na or tt supra wheels if you know anyone with some.
gmoney
Apr 22, 2005
97
CT
home1.myspace.com
not off hand but i will let you know, the car will be in eastford actually so thats right down the rd. What i will be doing to the car this spring is: jdm engine as is, spec stage 2 clutch, spec flywheel, 4.30 rear end and attach the new DP to my old exhaust that should be it but my main concern is taking out the old 7m and installing the new 7m with wiring and the fact that it is JDM so will be a little different. so hopefully it will be all good.
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
I have never installed a jdm motor into a toyota, but I have done a few hondas and they are close to usdm. there might be a few wires that need some work, but i can't imagine anything crazy. Just let me know whenever you plan on starting. I also have tons of tools to help, the only thing I do not have is an engine hoist, I have a engine stand though if you need to do any work on the motor while it is out.
Jon Martens
gmoney
Apr 22, 2005
97
CT
home1.myspace.com
i can get a crane without a problem, hopefully i will have access to the garage were it is being parked. but I will keep in touch maybe I can take a look at you whip some time peace...
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
If you need a garage and there is anyway you could bring it to tolland I am sure we could use my parents. Just an idea, or I could bring our portable one that I keep my car under in the summer time, and as soon as my car is running or I am back in ct I will let you know and you can come by and take a look or if it's running Ill come by your way.
Jon
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
Yeah I have been saving as much as I can, but I just keep buying new parts for my car every pay check. Oh well, hopefuly one day I will stop spending all my money on my cars, but that wont happen for a long time.
Jon
shaeff
Kurt is FTMFW x2!!!!
10
Around
putting a JDM motor in a USDM supra is very straigt forward. here's some tips for you:
1) drill out the metal pipe behind the head, as it is a JDM motor, their heater core feeds from the opposite side (where ours is blocked off). you should drill it out and attach a NEW hose for the drivers side heater core there, and block off the part thats blocked off on the USDM motors.
2) you'll need to swap a FEW of the connectors for your USDM connectors. if i remember correctly, they're all 1-wire connectors, so it's pretty easy. make sure you SOLDER them, and shrink wrap them to prevent corrosion.
3) as with any motorswap in the supra, be very careful not to crush the passenger side heater core outlet. it's only copper and will crush very easily, making a heater core leak inside the cab. not fun :(.
4) it's much easier to pull the engine and tranny TOGETHER. this way when you drop the assembly back in, it follows the natural contour of the tranny tunnel. i will never pull a 7m without the tranny attached.
thats all i can think of right now. i just woke up a little while ago... damn night job. :(
-shaeff
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
There are no more people in ct that would want to help or even come by? There ahs to be more people in ct with mkiii's. I just want to meet as many people as I can because I love learning new things about my cars. Hopefuly more people reply.
Jon
14u2c
RAFO
four-one-three
How far from Springfield MA are you? I did a motor swap be for I sold my supra and it took me 4 hour to pull out the old motor and put in the new one. I for got to mention that it was a 7mge. But how hard can it be to put in a 7mgte with a little help from your friends? I am willing to help if your not that far. Rafael.
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
Tolland can't be more than an hour away. I am pretty sure it is closer to like 30-40 mins, but it depends on how you drive.
Jon
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
I may actually need some help if you have any time soon. I am getting my rebuilt head on weenesday and then I am trying to decide if I want to pull my motor and put in new bearings because I had a bhg, but I am not sure if it will need them because it didn't knock when I took her off the road, I just do not want to get it all together and have rod knock. I will get back to you when I get my head because then I will have abetter idea of when I will need some help. I just really need hlpd on seeing iI need knew bearings and I need help setting the timing and tuning it with my suprer afc. Besides that, it is all pretty easy. I will get back to you and sorry gmoney for hijacking, but you are now selling your car so it dousn't seem like you need any help any more.
Jon
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
Do you by chance have an engine hoist(cherry picker)? That is the only thing I need to get and I do not feel like renting one becuase it costs so much so if not then I will just buy one. I need to pull my motor to check my bearings and make sure no water got into my oil when my hg blew. I don't think it did, but I am always on the safe side when it comes to my cars. I willg et back to you as soon as my parts come and thanks again.
Jon
14u2c
RAFO
four-one-three
My neighbor has one of the old engine lifts but it doesn’t fold up and it’s too big to fit in my Nissan. I don't have an engine hoist. But I am thinking of buying one of the ones that fold up. If I do get one I'll hit you back. .
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
Yeah I am either going to just buy one from sears or get one off ebay then this week so I can get everything done once and for all. You wouldn't by chance be able to weld would you? I just need my greddy bov flange welded onto my hardpipes and I do not know how to weld, nor do I have a welder(hopefuly soon I will know how and have a welder though)
Jon
