Peculiar sound when passenger door is opened
Backlash2032
1,823
Nebraska
There is a sort of grinding scraping noise when you open the passenger door. The hinges arent bent, the door is aligned properly. It doesnt hang or anything.
I am fairly certain that this noise is coming from the seat belt reel. Whenever I just open and close the door (without pulling out the seat belt or putting it on) there is no noise. (aside from the normal smack of the door.. :p) But if I do pull out the seatbelt after closing the door.. Then release the seatbelt, then open the door I get a grinding, scraping sound. But only then. Any ideas?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
The reel is designed to lock whenever there's a certain amount of forward inertia or if the belt is pulled hard. The lever fully disables this lock when the door is open. It doesn't prevent the belt from being put on with the door closed but many (if not most) people put the belt on with the door open.
So if the door opens in an accident the belt unlocks?
(my car didn't have this "feature" so I'm guessing it's a US thing?)
D.J.T.
877
Arkansas, United States
It doesn't unlock from the latch. It locks from the the reclining thing. so lets say you close the door & put on your seat belt, if you pull the belt too fast it'll lock & you won't be able to pull it to the length you need it. under heavy deceleration is when i notice it happen. it locks & i can't lean more forward & after it stays locked & its quite annoying.
So if the DOOR opens during an accident the Belt unlocks from the inertia reel was my question.....
(I know it doesn't unlock from the latch)
5
Thought it was the exact opposite? When the door opens, it lets the spring pull harder to wind the seatbelt back up easier. It's why if the lever is broken, the seatbelt is uncomfortable as it pulls tighter than usual.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Maybe it's just me but common sense would seem to suggest going in there for a look-see at what the problem is and what might be done to resolve it. You'll have to do that anyway if it needs replacing. Or were you thinking it'll fix itself?
Dunno P00 that's why I asked as I said earlier my car never came with that installed and none that I've worked on have had it.
Backlash2032
1,823
Nebraska
Jetjock, i know you're a smart guy, and i respect you. Just wanna get that out of the way. :p
But honestly, ive had it out, and I had absolutely no idea what would even cause that noise. All i could figure out was the little ball bearing that locked it.. Cause thats about all i could see. Im kind of half way scared to take it fully apart because its such a vital safety component..
And ive been running around without that side of the interior for the past couple weeks.. So i could have the belt out in a matter of 5 minutes.
5
More than likely just 20 year old grease (or rust since that belt is used less). Seat belts can be refurbished as well.
