pcv system problem...
drewmiller5007
taylorsville, NC
hey guys, when i bought the car the dealership had replaced whatever set up was in it before. they had it running from the valve covers straight to the TB nipple and nothing going to the accordian hose. that wasnt working right so someone told me to block off the TB port and just put mini breathers on the each valve cover so i did, however after a little while oil was coming out of the breathers and getting in the valley. so ive taken everything apart and cleaned the valley and am going to set it up back the way it was stock. being that i dont have any of the stock metal pipes for the pcv system is it going to be alright to run vacuum line from the TB port to the valve covers to the accoridian hose? and is these going to solve the problem?
Just make them all connected. You could also post in the wtb or look in the for sale threads. Im sure someone has one floating around in the millions of 7m parts everyone seems to have.
It shoudl clear up your problem unless you have excessive blow by from bad rings or something.
