Parking Brake Shoes same as Cressida ?
Davismj711
PA Mountain Supra
Well after 130,000 miles it is time to do the rear parking brake shoes. I have done the usual look at all other suppliers other than OEM and found nothing.
Has anyone tried or has anyone used the Cressida rear parking brake shoes ? When viewing Champion Toyotas parts online, the Supra and Cressida shoes are listed together on the list. I am unable to verify that they are in fact the same.
The reason I ask is that the Cressida shoes are easy to get from NAPA, Advance, Autozone etc, and much less expensive. The same can not be said for the Supra, as it appears they are OEM only.
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
I paid $130 for all 4 of mine at my dealer for my 87 Supra and Champion Toyota is less than that when I was looking around for parking shoes. I also tried tons of autopart stores and they do not carry them.
I'm over 160K miles and my brake shoes are fine...
They're THIN when they're brand new, and they shouldn't be taking much wear unless you're being stupid with it...
Davismj711
PA Mountain Supra
Poodles, Advance sells a set for $100.00 NAPA has a set for $39.00. OF course these are all for the Cressida. Reason for the post.
Even with my jobber discount at NAPA the price surprised me to say the least. But, if Jeff knows I would tend to agree with you.
I did look at rotors also, reasoning that they would at least have to have the same hub diameter for shoes to cross over. Unfortunately they are different numbers, but that doesn't mean the hubs have to be different. It could be hub diameter is the same but the rotor circumference or rotor thickness may be different.
I just feel like spending over $100.00 for the OEM shoes is high to say the least. I do realize we will always pay more due to our lower production numbers and current demand. It just bugs me .....
Davismj711
PA Mountain Supra
As far as the miles Poodles I hear you. Keep in mind however that I was not the original owner, so my 130,000 means little as I have no idea if * Someone * got stupid with it.
I am glad that it only took me about 44 years of wrenching and healing to realize that stupid hurts.
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
Davismj711;1097555 said:
Agree on buying and trying... Jeff how were you able to get the part numbers for the Cressida ? Champion showed both ( Supra and Cressida ) but neither had the part #'s..
I have catalogs. I work at a Toyota dealer here in Canada, I also have copies of all the global catalogs from around 1980 until 2004.
I can check information sources tomorrow to see if I can find some sort of diameter specification for the Cressida and Supra.
That being said, parking brake shoes are NOT wear items, and as such are generally not replaced for the life of the vehicle. It is one of the reasons they are harder to find. If your shoes are worn out, I would check to find out what else is wrong that caused them to wear out. If you know it was just you pulling on the parking brake while driving, well, then just throw a new set on, but if not, there's probably something binding or misadjusted.
There is almost no friction material on the parking brake shoes when they are new. They are not meant to wear out.
Jeff
Here's the page out of the TSRM, might want to check them...
Asterix
Lurker of Power
Vienna, VA
One of my shoes lost it's lining around 220k, so I replaced all four. That's more likely than rubbing off the linings under normal use. After 20 years of temperature cycling, the bond let go. At some point it'll be cheaper to reline the shoes than buy new ones...
Asterix
