If I still miss shifts after disconecting the Tranny computer, then more than like it's caused by shift selnoids, correct? Could it just be the selnoid o-rings?
The shift solenoids are bypassed completley when you unplug the computer and shift manually with the stick alone. What gear won't the tranny shift into?
If I run hard, even just a little 'spirited', I'll miss the 2-3rd shift. I have to put it in neutral shut it off & restart the car to get it to shift into 3rd. I bought new solenoids o-rings, but I haven't put them in yet.
Ok, that shift is hard to test manually because you can't get the tranny to go into 2nd - just 1, 3, and 4. When it misses a gear, where does it end up? Are you stuck in a certain gear? Compare it to this chart: http://www.cygnusx1.net/supra/library/TSRM/at/AT_012.html
And see if your situation matches up with a solenoid failure.
