i bought my supra with an already installed pacesetter header on it. recently during the engine swap, i pulled out the dipstick holder to clean up the block and matched it up to another one, and i found that the dipstick had been bent (curving bend) so it will fit around the header, there was plenty of room, the problem was that you couldnt actully put the dipstick in.
I just put on my Pacesetter header yesterday and ran into the same problem. All I did was just adjust the angle and position of the filler tube. I slighly bent it and turned the position to the right. Just between #3 and #4 exhaust. I am not sure what pacesetter header you have, but it worked for me. I will send you a pic!! Also go with an oil filter that is not as deep, but still the same circumfrence.
