P.I.C. Injectors in an 7m?
87nasupra
Scotty's Garage
Mar 2, 2006
993
Jacksonville, FLORIDA !
Guys, i picked up a project turbo ma71 a few weeks ago and found out that the guy was running 560cc PIC ? injectors in it. I dont know anything about them nor have i ever heard of them. He was running 10 psi on a t3/t4 hybrid ct turbo with fuel pressure reg. and a lex afm. I am rebuilding the engine now and desided to ask since i have them already. Somebody told me they run them in DSM motors. So tell me whats up. Anything is helpful. Thanks
bigaaron
4,692
Pomona, CA
www.driftmotion.com
The best money you could spend on your new engine is $14ea on the fuel injectors to have them clean and tested at www.cruzinperformance.com
He includes a new set of seals and o-rings with the service which would be about $30 by itself anyway. We have added this step as a non-negotiable part of all our engine builds now. RC also overs the injector service but they are $25ea injector and they use the same equipment as Cruzin does.
87nasupra
Scotty's Garage
Mar 2, 2006
993
i appreciate the tech data aaron. ill have the do that..........just that i dont know anything about these injectors and if they are even good enough to run in this engine. I dont want to put them back in if i might hurt it.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I am so with you on that. It's a shame to build a nice engine and then play russian roulette with questionable fuel injectors. I have not heard of the brand you have but even with an expensive name brand injector it's a good idea to make sure they all flow properly.
87nasupra
Scotty's Garage
Mar 2, 2006
993
Well, i found out that the injectors came from a big burly v8 domestic engine. The guy is running a set just like mine in his other supe and says they work fine. (he's putting down 375 hp to the wheels on 10psi boost) He has the same mods as me, but his car runs, HAHA.
