Problem #1
The coolant is boiling and spitting out of the overflow canister.
I'll start by saying the car has previously had the head gasket replaced by Toyota.
I have done a compression test as of today:
Cyl #, in PSI
1. 180
2. 175
3. 175
4. 172
5. 175
6. 170
Also, I have replaced my thermostat with both a 192 degree, and now a 160 degree to see if it makes any difference. (don't notice any difference)
No smoke out of the tailpipe, just coolant loss out of the overflow.
Also, I do hear the gurgling sound from the heater core, and have tried to bleed out the air, but doesn't seem to work.
I am looking for some ideas on what this overheating problem could be? What should I be testing/looking for to eliminate this problem?
Problem #2.
The car seems to be misfiring only between 0-5psi when keeping the throttle steady.
Changed the plugs, I *think* it helped a little bit, but is still hesitating. Car pulls hard under full throttle and boost though (8psi). So this makes me confused.
Help would be great guys, in need of some advice/suggestions on what to do.
Thanks everyone.
(sorry if it is not detailed enough, let me know if i have forgotten anything)
Cyl #, in PSI
1. 180
2. 175
3. 175
4. 172
5. 175
6. 170
Problem #2.
Thanks everyone.
