Overheating help needed
sirgeorgee
238
Hungary
Hi all
Please help me out.
I have a 1991 3000T .
On the highway over 130 kmh (90 mph) beside the water temperature a small red signal starts to come up with a loud beep-beep sound.
The temperature shows absolutely normal like always,no water running out everything seems ok checked everything ...
This warning comes up only at highway speed ,but the water temperature needle shows absolutely ok (and it works ,checked it)
We checked everything -thermostat,oil,water-everything is ok...????
How can I solve this problem please help me out guys....
Waiting for your replies
Thanks a lot in advance
George
8,894
Do you have a EWD for your country, model, and year? My car (US model) doesn't have the warning beeper.
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=137
What isn't shown on that page is the common power. If your is like ours, then you need to look at the sensor that turns it on. If it is an on-off switch, it will likely be grounded when you over heat. But like I said, we don't have that here, you need the EWD to see how yours operates. If you find no faults, then you can think about the combination meter.
sirgeorgee
238
Hungary
Hi Nick
Thanks for your help in advance because i am clueless....
My car is a 1991 7M-GTE Imported from japan
I don't have an EWD the only thing I found is this
http://www.boost.org.nz/Media/JZZ20 Conversion/JZA70 Conversion Docs/87-89 Supra EWD.pdf
Hope it helps -i am not an electrician expert so i looked through this ,but i don't get it at all (sorry):1zhelp::1zhelp::1zhelp:
mkiii222
Troy, MI
Someone correct me if I'm wrong, but don't Japanese cars have a 'speed warning' that pops up over a certain kph?
sirgeorgee
238
Hungary
Yes I think you are right , it is a Japanese made for Europe
But is it a speed warning?On the light it shows water temperature?????
I think the main problem is that my check engine light is not working at all-so i can't read the codes......
If anyone has an idea please let me know...
Thanks
George:1zhelp:
martin p
1JZ-GTE powered Supra.
Feb 5, 2006
215
East coast. UK
some European Market cars have the same speed warning beeper fitted, Normally goes off over, 110kph ish(from memory) I ditched the one on my Jdm car. Just remove the gauge cluster you will see a small white box on the back near the speedo with 2 wires( again from memory) just remove these and the box job done! no more beeping.
Also check the bulb for the check engine light, it has probably blown, So try a new one,
bozosoku
CT
If it is a Japanese market version a speed warning will beep when you go over 120 km/hr. When I rode in my in-law's Mark 2 in Japan, it beep at exactly 120 km/h, it has a digital dash so it was easy to tell. annoying the hell out of you. If all the gauges are OK I would not worry about it.
sirgeorgee
238
Hungary
Thanks a lot I will check it...
I really don't understand why they put this on our cars?
I check it try to fix it and get back to you
Apr 6, 2005
339
Alpharetta, GA
From what I deduce from the user manuals and electronic wiring diagrams for the various JDM electronics, such as, Apexi, Greddy, Blitz, they have provisions to eliminate the speed limiter. So, your car may also be speed limited?
sirgeorgee
238
Hungary
Hi all
PROBLEM SOLVED
So the speed warning is a small black thing located on the back of the board,just beside the speedometer incoming cable....
You don't have to cut the 2 wires just have to remove this small black round thing(Made in Japan cars only) and no more beeping....
We fixed the check engine light so I can read codes now ----:naughty:
I bought the car in a very bad shape -somebody removed the W wire from the joint going into the computer -I am sure that by that time the check engine was coming on constantly annoying the hell out of him-but he did not remove the bulb noooooo-he removed the wire (IDIOT)
So now this works also and I am very happy
I will try to post a picture of this speed warning black round thing just in case a japanese supra pops up at you claiming the beep-beep sound(hehe)
:biglaugh:
sirgeorgee
238
Hungary
Hi all
So as I promised here are the pictures of the speed warning sensor.
It is only in made in Japan supras,located behind the dash-if you remove it -no more beeping and flashing overheat signal...
Good to know if you happen to meet a Japanese Supra...
Hope it helps you guys also:naughty:
sirgeorgee
238
Hungary
The buzzer came on above 130 KMH (80 MPH) and the warning light came up,but the ECU didn't do anything so we were able to go faster-just I did not enjoy the cruise very much cause the loud beeping and the flashing signal...
The ECU might control the speed also but it must have been taken care of the former owner...
tbcmorris;1325805 said:
interesting....do you just have a buzzer or does the ecu actually limit speed
