Overdrive light
Red
What should the RPMs be @60 MPH (in overdrive ;and out of overdrive)?
If the OD light is burned out does it effeact the shifting into and out of OD?
mkiiichip
1,434
WI
There are to many variables to say what you RPMs should be at, in or out of OD.
Can you see and feel the RPMs change when you shift in and out of OD (while at highway speeds)?
A faulty dash light will not affect OD performance.
Also, what is the issue?
