Ok, so we've now finished the head rebuild on Suggestable's GTE. During the shakedown runs it's pretty obviously running more boost than a stock supra.
(Another boost gauge capable of reading up to 1.5bar is on the way, but currently boost goes off the top of the stock gauge)
I'm suspecting one of two causes:
1) Given the evidence found during the strip and rebuild of general poor maintenance and lack of use, it's possible the WG is seized shut. (Although my own experiences have generally shown most wastegates to fail open)
2) The wastegate spring has been tampered with. (Seen a few references to people shimming the WG on here, but have not yet located an actual write up)
So...
How much boost will the stock turbo produce if the WG is stuck shut? (Car seems to be stock bar an aftermarket induction kit)
What is a safe level of boost for the stock fuel system? (I've been reading and 10psi seems to be mentioned a fair amount)
Assuming it has been shimmed/seized I guess that would go someway to explain the BHG the car was sold with! :kickinthenuts:
So...
