OVER BOOST
THOBES1
4
Waterville, Ohio
I just bought a 87mk3 turbo - For some reason it keeps over boosting. I have read the code and it is definately over boost. The is completely stock with an open element filter. Ive checked all vacumn lines and intercooler pipes to the best of my ability. Guage is alittle slow seems to hit over boost about 5psi. I have no clue but as far as I have read the car shouldn't be over boosting untill 11.7psi. Just trying to get an idea of how to fix before I start adding parts.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
What you have here is a Boost Leak. The code you are getting is basically the AFM seeing to much air. Without a boost leak you will be able to hit around 13psi before seeing this code.
Check for Boost Leaks...they can be hard to track down sometimes but I'm 100% sure this is your problem.
SLO-MK3
Not on the 1jz bandwagon
Nov 4, 2006
246
Plumas Lake, CA
It would over boost because the w/g would never open, but he is hitting f/c at 5psi which is under-boost. That is related to a boost leak as stated above.
MKIIINA
Destroyer of Turbos
Plano, TX
i second the boost leak threory, check your lines as there is more than likely a hole in it somewhere.
