First off I apologize if this is in the wrong section. It kinda fits into a couple
Anyway I have been doing a rebuild on my 7mge and I am at the point where it is ready for reassembly, however I just found the following for sale for 350$
7mgte with rod knock
Upper and lower intakes and tb
exhaust manifold with t3 flange
5 je pistons ( idk where number 6 is)
9x 440 injectors
6x ge green plug injectors
1 ge ecu
1 yellow plug gte ecu
1 grey plug gte ecu with harness ( harness was modified for cressida and is missing cps connector, csi connector, and all emissions connectors. Probably more stuff missing it was heavily modified)
2 alternators
2 ps pumps
2 water pumps
2 starters
trd oil cap
fuel rail
7mgte afm
lexus afm
coil packs and bracket
I believe all sensors
cps with no connector (it was hardwired to the harness)
I have a 6m crank with bearings to fit that I was going to put In my ge but from searching the forums it seems that my crank and bearings should fit the gte. Correct?
Also the gte in question supposedly has had block and head machined with hks headgasket.
Any opinions on whether or not I should take this deal? Im on a bit of a budget.
ill see if I can get the pics on here.
9x 440 injectors
1 ge ecu
2 alternators
2 ps pumps
2 water pumps
2 starters
trd oil cap
fuel rail
7mgte afm
lexus afm
