Only 6 psi ??
a_sesshoumaru
Suprita
Jan 7, 2007
455
El Salvador
I upgraded my turbo to 50mm, i have 3" free flow exhaust, shimmed my wastegate and still same 6psi, i have no codes. What could it be?? if it is the wastegate if i conect a MBC would it raise my boost? or would i still have the same problem¿??
Mrbaboon
277
Victoria, BC
Also check for exhaust leaks around the exhaust manifold connections to the block and turbo, and also the EGR.
I had an exhaust leak on my manifold and I could only boost to 4 PSI (couldn't hear it over DDP and straightpipe though).
