Now i know there are tons of mapping diagrams for the 7mgte and i've studied them all. i'm no master mechanic and i have an odd setup/issue with how i received the car.
*now plz before you make judgement for what i'm about to tell you...I did not do this to the car I am a grown man with children I would not make this decision I traded a TV for this car (awesome deal) and it was growing trees off the valves..but I digress*
so the IMG above shows what im missing off the car. I have fully rebuilt the engine from pistons up, cut down he trees and polished everything all nice n fancy. Runs great but I KNOW the vacuum is jacked or the hose routing etc.
-----*sigh* im also missing the power steering pump ..completely *----- and i know that also has lines running to that little valve thing on the bottom of it.
That big vacuum nipple on the left side of the intake next to the fuel pressure reg is just capped. I looked around online saw some ppl capping it most not. what exactly was happening here? I have both the VTV everything else but i have no idea how to run this stuff to make it work especially without the metal hose router/plenum?
I live in rural Iowa so if its possible to not have to buy a new PS pump and metal router that's no big deal but I don't fully understand how to tie into the rest or make it correct without it.
Do I absolutely need them both? can this even be done?
Like I said car runs great no errors but I know this should be rectified.
Any Ideas? OR is it find a pump and metal router. both fairly hard to find in my neck of the woods..Literally
