I have a Soarer R154 with the supra extension housing, everything was perfect but then I rebuilt it and the output shaft oil seal leaks. I changed it twice now with brand new toyota seals, the fullface side facing the rear of the car and yet it keep leaking quite badly. The driveshaft is the same one, nothing happened to it and the surface is almost perfect (the chromed female spline exterior). I even tried a W58 one (some say that it is a tad tighter, not sure) but no dice.
EDIT: forgot to mention, I'm running 3L of MT90 and a 3" aluminium 1piece driveshaft
Is there a breather on the R154 ? why does it keep leaking.
