Okay, I think I found a REALLY SIMPLE possibly even more accurate way to set TPS. Okay heres all you do.. reset your computer from any codes it might have. Turn TPS CC all the way then jump E1 and T. Okay now turn on the ignition you should get a constant fast blink of check engine. Now SLOWLY turn TPS CW untill it stops blinking and displays code 51. Okay now SLOWLY turn TPS CC untill it starts blinking fast again, tighten and re check. NOW! hit the gas VERY slightly, it should go from blinking fast to code 51 under very light throttle. YOUR FINISHED!!!!
Now you know the ECU detects even the slightest throttle position not based on your meter but actual reading based on your car and your throttle positiion!!! And you also know the ECU detects closed throttle at rest or you would get a code 51 =)
You can do this with one person by moving the TPS very slightly and re-checking (thats what I did) or with 2 ppl you can do it really quick.
No meters
No taking anything off or apart
No feeler guages!!
No meters
No feeler guages!!
