OMG!!!! Coolant leak...
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
My 7mgte leaks coolant from what looks like the Power steering pump???
The power steering also fades in and out when it happens.... Ok bad ps pump!!! But why am i leaking coolant???
If i cut the PS belt will it stop???
I know i will lose power steering but i dont care if i saves my engine!!!
:1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp:
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
plaaya69 said:
Check the 90degree rubber coolant hose under the thermostat housing and also check the coolant hoses form the turbo.
Newb Q:
Where is the coolant hose on the turbo???
mk3some
78
buffalo
dude, i will bet ya cutting shit wont fix your problem, just a thought...also how is ur coolant leak having anything to do with power steering? your pump has a special cooling passage on it or something?! hmmmm
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Yah its coming some where above the ps pump... I think its coming from the water pump... I cant really see it that well because the power steering pump crapped all over the engine!!!
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
The coolant is leaking around the ps pump and the main pulley... It's getting messy please help.
