Don't know about the Huskey...I do know about the Craftsman; that's what I used on my ARP studs.
You could alwys have one machined like Trannix did above, but the Craftsman worked fine for me.
Use the ARP spec sheet that came in the box for torque. From memory, it's 81 ft/lbs using moly lube, 105 ft/lbs using motor oil. The studs should be threaded into the head dry. Make sure you follow the TRSM sequence for torquing the studs in 10 ft/lb increments. Do not over torque!
Do not use a spray sealer if your MHG is new...it will destroy the factory coating.
I assume you got your front plate machine level with the block deck when you had it re-surfaced for the MHG RA spec. Make sure you use RTV along the front top of the front plate per the TRSM...not doing so will result in an oil leak.
