ok im probably annoying....
1_slo_92
145
Hillsboro Ohio
some of you but have a ? about a pic that was posted, 2 main area's The coil packs on the firewall I drew (to the best of my mouse skills) in red where it will be located, and on top of the throttle body is these the lines to take care of the coolant flowing to the tb?
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
You can mount the coil pack there, I've seen a few people that have done it. The lines on top of the throttle body are vacuum lines go to the EGR I think, but theyre blocked off in the pic.
1_slo_92
145
Hillsboro Ohio
ok so where are these dang lines for coolant to go into the TB?? I have looked on the pass side of my block for these lines and can't find them.
1_slo_92
145
Hillsboro Ohio
which side front or back? Just route them together and leave it or what is involved with this? Also the little green gadget coming off the top of the thermostat housing, what the heck is that and how can I bypass (if I can, which I should be able to since the 1 comes from the top of the TB, and the other from the charcoal can) just put some small caps on there? Like the ones on this TB?
Yellow 13
Lurker
Apr 4, 2006
2,308
mustangman05 said:
how do i mount the coils to the fire wall what do i use to secure them and get a good ground if the packs need one....
I havent done it, but I think sheet metal screws would work if you made a bracket for it. Youll also need longer wires. For ground you could probally just ground to the wall.
1_slo_92
145
Hillsboro Ohio
well if you mount it right there you can switch up your wires right? I'll try it and let you guys know. I think im going to start a build thread tomorrow, on just the final stages of this particular supra.
