I had my car tuned a few weeks ago, but I think the guy screwed it up after it came off the dyno. Follow along.....
When I started to drive the car away from the shop, it bogged a little, so I took it back. He hooked the laptop back up, made an adjustment & the car ran good enough for me to be happy. Near the end of the 80 mile trip home, it developed a miss.
Also, I cut the boost back from 18.7 psi to 15 psi. I felt as though the tuner got too much out of the 450cc injectors (467 whp), so I didn't want to push it.
I changed the plugs the next day & the car ran great. The old plugs were completely black & covered with soot & the bumper above the exhaust was covered with soot too (not oil though). It continued to great for about 70 miles or so, & then it developed the same miss again. I changed the plugs & the routine started over again.
Last night, when driving home, I hit 10 psi or so & the car started running like crap again. There is a lot of smoke pouring out of the exhaust & one, maybe two cylinders, aren't firing or are missing badly. The turbo would spool insanely fast from 6.0 vacuum to 3.5psi, but that's as high as it would go. It would start to stall the motor too, not letting it climb above 3.5k rpm. I changed the plugs again, drove it for 5 miles, same problem. When I pulled the plugs tonight, all six looked as though they hadn't been changed in 1000's of miles, not just 5. :nono:
I checked all of the I/C couplers & couldn't find any leaks. Not that it would matter because it's MAP, so unless I'm missing something, that wouldn't be the source. I also ran a compression check & all cylinders logged between 145-155 psi after 5-7 compression strokes. This is good, I thought that I thought I had burned a hole in one of the pistons.
So that's the symptoms, but I'm trying to figure out the cause. It's running rich as hell, but why? My first thought is one of the injectors, maybe two, are stuck open. But if this was the case, wouldn't only one or two plugs be shot & not all six?
Any advice?
Any advice?
