Ok so for those who havent seen the couple of threads ive posted... heres a quick summary of the situation. LONG BUT PLEASE READ IF YOU KNOW ANYTHING ABOUT AUTOS....
i have an 87 NA auto. it runs PERFECTLY. however the auto is giving me problems. i took out a nappy looking 87 ect ecu and put in a spare 91 ect ecu not thinking anything of it. then i drive the car i put it in D and it feels like its in 4th gear. so i think ok either ECT ecu needs to be compatible (an 87 one) or a solenoid is bad. so today i go to the junkyard and get another 87 na auto ect ecu.... and pull off the pan and pull out the solenoids...bench test them...and they both click open and closed fine. so the solenoids are good. however i only tested the number 1 and number 2.... so the lockup is just ASSUMED good.
so i put a new filter and gasket on and the solenoids back in, bolt the pan back up and fill it up with ATF. i plug in the 87 ECT ecu. test drive it.....before if put into drive it wouldnt MOVE at all unless you pushed the gas pedal...then it would SLOWLY go like i said as though it were in 4th...well this time i put it in drive and let go of the brake and it moves forward like normal. but i go to step on the gas and now it feels like its in 2nd gear. it quicker acceleration then before but still bogging down until it gets higher in rpm then it goes like normal....
also i can put it in L and in 2 and it works perfectly...pulls strong (for an NA lol) and i can even do burnouts no problem
now...im out of answers...BUT theres a harness going into the top of the pan on the side of the tranny (drivers side) it branches out to a 3 pin connector on the side (has what seems to be two white wires and a blue wire ...they are kinda dirty) and then the connector attached to it a SINGLE green wire that is cut and goes nowhere...
then the harness continues on and go to a 6pin connector that has mostly all white wires it seems...but this connector isnt plugged into ANYTHING and icant find anything to plug it into.... theres a 4 pin connector by the circuluar plugs but it doesnt fit etc....
im convinced this is the problem and the number 1 and 2 solenoids arent getting when they are supposed to or something.... does ANYONE have any info on what this harness is for?
PLEASE HELP...ANY INFO WOULD BE GREAT I NEED TO FIX THIS ONE PROBLEM SO I CAN GET THIS CAR SOLD BEFRE IMOVE ON FRIDAY!
THANKS!
THANKS!
