Ok another hg ?
JStoked
646
Edmond, Oklahoma, United States
So i went to check on my block Saturday. I found out that they had to shave it 0.020 witch is alot more then i was expecting. So i am planing on boosting around 15lbs so do i need the 2mm hks or the 3mm? I have a 1.2m already im pretty sure after all the research iv done that the 1.2 is no good to me anymore.
gottadiesel
Flyin Low
Feb 16, 2009
459
Vancouver, Washington
You need to measure the following:
Current Deck to VC surface = x2
Current Deck to MB Saddle = y2
Stock Deck to VC surface = x1
Stock Deck to MB Saddle = y1
IIRC stock compressed HG is 1.37mm
x1 - x2 = x3
y1 - y2 = y3
x3 + y3 + 1.37 = your need HG thickness
I do not recall what the stock measurements are (should be able to search on here and find) but for example these were my current measurements:
Deck to VC surface - 115.82mm
Deck to MB Saddle - 198.15mm
I used a 2.00mm (1.90 would have been exact, but close)
