Oil tube from valve cover size?
Cedrock15
The Sarcasm Specialist
Sep 29, 2005
126
Bucks County, PA
Hey need to get a oil hose to replace mine. its the oil hose that goes from the drivers side valve cover, its toward the front of valve cover and like 1/2 inch below the Oil cap and goes down below the alternator. Can someone tell me the length, and diameter to get and will a regular autoshop Hose work?
(its for 87 turbo auto.)
turbo
Mr. Clean
Apr 27, 2005
135
Calgary
I am pretty sure the hose is 3/4" and is around 18 inches or so because there is a slight bend to it. I replaced mine a couple weeks ago and I recommend you take it off and then go down to the NAPA or whatever to get the best hose because it is form fitted. I got mine from Toyota and it is fairly pricey.
Geoff
Cedrock15
Sep 29, 2005
126
Bucks County, PA
Thanks for response guys, just picked up a 3/4 inch and 24 inch long (guy was like get 24 inch which i knew was to much, but got it to not look cheap lol) Hopefully it fits, doing the switch tommorrow, and will post if its wrong/different size. Thanks again!
Cedrock15
Sep 29, 2005
126
Bucks County, PA
Arghh, nope, nope, nope lol. Spent more time today trying to find the correct hose than total instalation time. Got 5/8 first...way too small, went and got the 3/4 inch and it took alot of work to just get it to fit on, but wouldnt go on more than like 1/5". Measures the original and actual size is 7/8 for anyone thats going to be changing this. The problem is nobody carries that size, I checked pepboys, autozone, home depot, lowes, and none of them carried a 7/8 hose. So i just heated the 2 ends of the 3/4 and they fit really snug, so tight i probably dont need clamps (but used them anyway)
Thanks for input,and the actual size is 7/8 but a 3/4 can be heated ...alot to fit snug on there. Oil leak , bye bye :wave:
turbo
Mr. Clean
Apr 27, 2005
135
Calgary
Glad to hear you muscled the 3/4" on. Sorry about the wrong measurement because I thought that was the size from when I replaced that hose last month.
Geoff
