oil through the intercooler pipes
mirage83
457
Georgia
917mgte;1253359 said:
i have oil going the intercooler pipes any help?
How much oil are we talking here? Couple of teaspoons or a couple of quarts? A little bit is more-or-less normal for our turbo's, but when it gets bad you've got problems there. Check your shaft play (both radial and axial), and if there's a lot of play along with a lot of oil start saving up for either a rebuild, upgrade rebuild, or replacement.
917mgte
115
butte mt
a good couple quarts but my shaft is good
mirage83
457
Georgia
Any bluish smoke out the back when under boost? If your rotating assembly is tight, the seals and journal bearing all good it could just be accumulation I guess. Maybe someone with more long-term experience with the CT26 will chime in, as I'm relatively new to the Supra and still learning as I go.
AjWit
Boostin without Boost.
Jan 31, 2009
92
Pittsburgh, PA
I had a small build-up when i cheanged out my upper IC piping. But mine wasn't flowing out or anything, just enough that i could run my finger around the inside of the pipe and get my finger wet. Checking shaft play next week when i pick up another turbo.
paradox616
472
Melbourne, Australia
could be blowby, i had this and the crank case pressure was forcing all my oil into the breather and into the intake... i thought my turbo was screwed till i checked it all out, i have 0 shaftplay, btw a little radial shaft play is normal as when it spools up it stays centralised (because its balanced)
grimreaper
2,180
Dallas
^ not true, years of buld up or shot rings or pcv...
before i enlarged my pcv ports i had issues with large amounts of oil getting sucked through the intake an building up in the lower ic pipes
was the turbo even removed and inspected?? all im hearing is "i saw oil in there and im replacing things"
877m
65
Lewiston, NY
i just finnised building my motor and i have oil in the ic piping iwas told it is normal for these cars but mine has a thin lineing not alot sitting in there
