oil thermostat question
spiller
582
Australia/Chicago
ive heard a few stories about the mocal thermostats failing which is why i steered clear. I went with the earls in-line. About 100 bucks from summit.
supraking16
93
georgia
are you nspeaking of the earls stat that looks like an aluminum blockand 1/8 npt for sensors or anything u want. how well did it install did it feel like a good unit.and should i buy a oil temp sensor and gauge while i'm doin this. its seems like i will want to be able to make sure the cooling system is working at all times.and what is a good oil temp sensor and gauge. thanks
supraking16
93
georgia
i believe im goin to go with an autometer guauge and sender from jegs performance. with a digital read out. ive used autometer in the past pretty good product. has anyone else ever used an autometer oil temp gauge. I also looke up that aerls it said it strats opening at 160and fully opened at 180 is this good. if so ill go with this stat sense it does have the ports allready.
p.s spiller what is your temp read after its fully warmed up using the earls stat. Ill be using a 11x8x1 1/2 b&m stacked cooler
supraking16
93
georgia
i likes the earles one since it already has the 1/8 fitting for sensors though. but it wasnt for that i would have tried the derales stat. i was planning on installing the cooler between the intercoole and condensor. butim installing the ic at the same time will i need a lower water thermostat to help keep it form over heating since there will be all that in front of the radiaitor
