oil system
maitai69691
280
hilo hawaii
im about to put in a used eng i just got and wantedto know how do i prime the oil system befor start up. dont know how long its ben siting i bought it from a eng importer. so its empty of all fluids.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Don't crank for too long at once, no more than 20 secs at a time or so
Give it a 30 second rest or so to let the starter cool down, then try again
Repeat until you see some oil pressure on the gauge!
maitai69691
280
hilo hawaii
I was just wounderiif there was a way to pme the oil system like u would on a ie..350 eng where you hook up drill to the l pump shaft and spin the oil pumtill you got oil in all the gallies or od oil psi. but thanks for althe info
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
Jaguar_5;1040358 said:
Theres no way to do that on a 7M without taking apart the front of the engine
Well, you could just turn the crank by hand? But have fun with that vs. just turning a key :icon_bigg
drbowser3
The Doc is in...
Jan 17, 2006
215
Tampa,FL
IwantMKIII;1040133 said:
add new oil, pull EFI/Eng Main Fuse and crank for some time.
Make sure you don't pull the headlight fuse on accident.....:1zhelp:
I usually just unplug the injector resistor pack.
maitai69691
280
hilo hawaii
sure it does if its a runing eng but its ben sitting for wile empty so it could take a wile. For example just finished building a 350 and i took like 10-15min with a drll spining the oil shaft till we had all the oil pasages filled.
LOL not that I'm saying to do it but I used to use my starter to get the car back in the shed when it was a manual (after breaking it bad enough that it wouldn't run)
My drive is uphill!
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
TurboWeenie;1042384 said:
IJ, what does removing the plugs gain you?
Please pardon my noobishness.
For one it won't start the engine ;)
Two its not as hard on the starter since there is no pressure in the cylinder so it shouldn't heat up as much since it will be running so long.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
exactly.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
I figured I'd bump up this thread instead of starting a new one....
I just finished my GE to GTE swap, and I'm trying to prime the oiling system before starting the engine. I cranking the engine 15 seconds at a time, then give it about a minute to cool the starter & wire down. So far, I've cranked the engine at least 20 times (20 - 15 second bursts); and the oil pressure gauge hasn't budged off 0 PSI.
My question is, how long do you usually need to crank the engine before you see the oil pressure gauge start to move?
