Im experiencing some strange oilburning episodes.Usually after i start the car and let it warm up (2mins)and start to drive approx 3-5mins into the drive when im stopped at idle there is smoke coming out the exh.The smoke is like white smoke with some bluish hue to it.It seems to last only 30seconds that i have noticed.Now the motor is 7mgte rebuilt less than 5000kms ago,hiflo'd ct26 (less than 40k old) brand new rebuilt head with new valvestem seals,auto,blitz airfilter,blits dsbc,apex bov,trust 3"exh.It seems to happen after i have given it a bit of a "high spirited" drive of around 10-20mins,cruising at around 100-180kms.I let the timer idle for around 3-5mins depending on how fast i was going.the oil i am using is penrite 15w-60w.I was told by the autoshop guy to stick to the same brand of oil as each manufacturer used different detergents,additives etc and u cant fully flush them out at oilchanges.I also change the oil every 2000kms and has come out dark brown but not black(if this helps) Ive had valvestem seals fail in the past and this is not them(i dont think so anyway).I am worried that it may be the turbo oilseal that has/is failing at times.Sorry if this question seems a little long but i want to give asmuch information as i can.Any help/ideas will be much appreciated
Thanks Mik.
Thanks Mik.
