Oil return lines.
1Relentless87
Guest
Is there any other way to return the oil besides punching a hole in the oil pan?
1Relentless87
Guest
Will there be any backup issues and can I use for both oil feed and return?
Bishop92t
773
USA
www.ma70.com
I assume you're trying to find an oil supply for a turbo transplant, in which case tapping into an oil filter relocation kit should work.
1Relentless87
Guest
Thanx for the info and do you know who makes a relocation kit for the mk3?
1Relentless87
Guest
With this mod do I still have to buy the oil feed and return line kit sold by 935 motorsports for my conversion?
Bishop92t
773
USA
www.ma70.com
You can buy any of the Permacool kits as they include the correct adapter to fit. Our oil filter thread is pretty common so it shouldn't be hard to find something.
As for the 935 kit, by their description I'd say it's probably useless to you. If they had a pic I could be more certain.
Shawndude
Van BC
I think people are missing the question here:
1Relentless87 said:
Is there any other way to *return* the oil besides punching a hole in the oil pan?
I'm guessing we're talking about the oil return from a turbocharger. If so, no way can you splice it into a "filter relocation kit" or your turbo seals will leak like a bitch.
The outlet of a turbo has to be free draining with no pressure, and as large as you can fit. The oil pan is your best bet.
