...I am going the 'keep it' route, as far as the oil pump goes. I mic'd and measured all clearances - they are perfect after 143Kms - so why change it.
DeanMarcum (a member of other forums) once said that he mic'd brand new pumps that did not meet specs. If there is no wear and the specs are 'on the money', why change it?
Keep in mind:
1) The oil pump always has oil it, unlike the cams & cam saddles (when you first start up) so wearing it out is harder than other components.
2) The oil pump has little force acting against it, unlike other parts such as cams within their cam saddles, because each valve spring exerts 35lbs – times two valves springs at a time (70lbs), times six lobes per revolution.
I would definitely check out the oil pump as the TSRM states, and not just assume it is good. There are a bunch of things to check for also....
