hi, i jst measured my oil pump i got out of a 7mgte block.
i measured it per tsrm
.051mm body clearance
TSRM MAX-0.2mm
.457mm backlash
TSRM MAX-0.9mm
side clearance (didnt know how to measure that)
but i noticed the drive shaft sits a bit higher than the driven gear, and it has started to rub against the top cover. is that bad?
i know its best to get a new oil pump but i was just making sure if its bad or good. Thanks.
TSRM MAX-0.2mm
.457mm backlash
TSRM MAX-0.9mm
