oil pump Q
odin
13
Oklahoma
i found out my oil pump is bad and i need to replace it my question is do i have to completely remove the engine to change the pump? or can i just undo the mounds and lift it enough to get the pan off?
thanx
odin
13
Oklahoma
my stock gauge wont come off 0 and when running the engine makes lots of noise like it has no oil pressure and i took the valve cover off and the cam was dry.
soc chaos
Oklahoma
Check to make sure your oil sending unit wire is hooked up and on good! I dont know how accurate this is but I was told to take the oil cap off, start the car and see if you can see oil moving. Hopefully someone more knowledgeable then me will have more info!
odin
13
Oklahoma
i was afraid of that. i do have an extra engine i was thinking about rebuilding. i guess i will go that route.
airhead04
1,489
Lima, Ohio, United States
Yea, I would listen to gaboon, he helped me out ALOT when my oil pressure gauge wasnt working. Helped me fix the problem too.:icon_bigg
Is your gauge stock or aftermarket? As for the noise, can you get a vid of it?
odin
13
Oklahoma
my gauge is stock and its hooked up, and i know there is no oil getting to the top of the engine.
