Yes, and yes. Though it doesn't change your oil pressure at idle, it certainly does affect it at RPM.
There are two of these - one is a bypass on the oil pump itself, and the other is the bypass to the oil cooler. Both are pressure valves and can be shimmed to give you more pressure in the engine at RPM.
