I've read many threads lately regarding low oil pressure and have seen a bunch more on rod knock, and am wondering what the prerequisites are for oil pump replacement.
It should go without saying that it's cheap insurance to replace the oil pump on a built motor, but how about on a bpu? My engine has approximately 150k miles and shows great oil pressure--about 40psi @ idle cold, and about 20-ish psi @ idle warm. Cruising at about 3000rpm once warm, my pressure is just above 40psi. So, everything seems ok...for now.
When the oil pump fails, does it tend to go in a catastrophic fashion? Or is it typically a gradual deterioration in pressure?
Thanks in advance guys!
