oil pump driveshaft removal on early 7m?
supra90turbo
shaeff is FTMFW!
MA, 01440
well, i got my engine out and just about down to a bare block.
but, i noticed that the oil pump driveshaft is not the same as when i stripped down my other 7M, which was a 90... so, the question is, how do i get that little fellow out of there? i dont want to be prying on the front case trying to get it out...
thank you.
kurt
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Well, maybe i can help. My engine is early 89 so it has square mounts. The oil pump accessory driveshaft is connected to the block via one bolt. To access this bolt you must remove the front aluminum cover with the 2 oil seals in it. It can not be pulled through the front cover. Does this help at all?
eric
supra90turbo
shaeff is FTMFW!
MA, 01440
yeah, i dont remember how i removed it on my 90 block....
i have not removed the front cover, that is why i cannot see how it comes out.
thank you eric. that helps a ton.
although i would have done that eventually, you saved me from wondering more about it... ambition has been low lately.. lol
thanks again
kurt
