Oil pump drive shaft bearing replacement
ca91mkIII
126
Franklin
I am in the middle of rebuilding my 91 7M motor and I am wanting to replace the oil pump drive shaft bearings and I am wondering if anyone has done this before and what kind of a tool did you use to remove/install the bearings?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,241
Atlanta
LOL- agreed.
I replaced mine, but it was a serious pain in my butt, and I had to replace one of the replacements because I gouged it so bad.
I DID learn however, that it's a bit easier(but not much) to fit if you freeze the bearings for a while. Then you have to polish them to the right size once they're in.
ca91mkIII
126
Franklin
They have to be replaced now because I have torn the outer one up trying to get it out. What makes me nervous is how soft they are. Especially since I read that hot tanking the block for engine machining damages the bearings.
