oil presure
mista_sup
211
atlanta
when i start the car the oil pressure garge goes all the way up and gradully comes back down to 0. has anyone ever seen this before.
antman
632
TN
Nope, but I would definately fix it. Couldn't tell you what is wrong but theres not much It could be. You have the sending unit and the reciever gauge. Other than that. The only thing that could keep that gauge from working is a bad fuze or faulty wiring.
If you haven't already, save this. If you have, make sure to refer back to it alot. Good luck. You'll get it fixed.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=BE&P=36
p5150
ASE and FAA A&P Certified
Central Idaho
check the wire on the sensor and ensure that it is still attached. It may be temporarially grounding out on something
