Oil pressure
mkIII213
87
Dallas, Tx
For a reason I am unsure of, my car has very low oil pressure once the engine is warm. After a cold start the pressure is normal, but once it warms up, it drops down to the lowest notch on the oil pressure gauge and just rises a little bit once I reach the 3k rpm mark.
What would be causing this?
mkIII213
87
Dallas, Tx
IJ.;1048861 said:
Worn out engine.
(it would pay to confirm it actually has low oil pressure with a mechanical gauge)
So you are saying the engine is crap? I will probably do that oil pressure check asap.
brs86supra
395
suffolk,va.
not trying to hijack the thread, but what would make the oil pressure sky rocket all the way to the top of the guage? heres a vid of what im talking about.
brs86supra
395
suffolk,va.
well i know that the pump isnt shimmed, but not sure on the reliefe valve. could it be doing this with too thin of an oil or something or maybe clogged filter. iirc i think i put 5w-20 full synthetic in there last oil change (which i believe was a bad mistake)
brs86supra
395
suffolk,va.
ok gotta quick question, could the fact that i am using the gte oiler cooler and filter bracket on the ge motor cause this, seeing that there is a releif valve in the gte filter braket and one in the oil pump also, or no
jdub
Feb 10, 2006
10,730
Valley of the Sun
5W-20 is a bit thin, but it won't make your pressure shoot up like that. Sounds like the oil pump relief valve is stuck. The relief valve in the filter head should not cause this...a common mod is to eliminate the stock filter head and go to a full flow cooler circuit.
brs86supra
395
suffolk,va.
im not sure, i think the battery may not be strong enough for the car or something, but the voltage does go up once driving the car around, up to 12. so could this high oil pressure hurt my motor
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
doesnt too high a oil pressure 'wash' the bearings? i just remember that from my DSM days when people would say 90-100psi on a cold start up was bad...
but more importantly, its finding the cause of it, i would double the check the wiring to the sender, along with the grounds on the battery just in case.
brs86supra
395
suffolk,va.
well the wiring to the sensor is good, cause if i unlpulg the wiring from the sensor it will not read anything. and the battery grounds are all good. so where would i go from there. b/c the gte oil filter bracket adn teh oil pump both have relief valves. so what should i try to do first. could two relief valves be a bad thing
jdub
Feb 10, 2006
10,730
Valley of the Sun
High oil pressure does not "wash the bearings"...you do need to find the cause. My bet is the oil pump relief valve (like I said).
