Oil Pressure Unit Size
1fsts13
Official HG Supporter
Jan 18, 2006
4
Vancover, WA
Trying to hook up a mechanical oil pressure gauge in the 87 supra turbo, curious the size of the adaptor that should be used into the block to replace the stock sending unit.
BSP and NPT are close but there is a 1 TPI difference in the threads (Threads Per Inch) And the taper angle is different so while they will screw into each other they won't seal correctly.
