oil pressure sending unit
SUPERSNAIL
You have much to learn...
Nov 13, 2008
71
Albuquerque N.M.
The car is an 87 turbo 5 speed,
The issue is i get no reading on my oil pressure gauge on the cluster at all, I have had it give a little wiggle here and there when started cold. I got a used sensor off a member here just to see if it helped. I went to install it and what i got from the sm member looks nothing like what i have on the car already. I attached a photo i used as a reference for the location and the sensor i received from the sm member looks just like the one in the pic. Do the sensors vary from pre 89 to 89+, auto to 5 speed, or turbo to non turbo? I would really like to have that gauge working.
SUPERSNAIL
Nov 13, 2008
71
Albuquerque N.M.
figgie;1251492 said:
That picture is the new one?
Look like the OEM oil pressure sender.
The picture is what the one i got in the mail looks like. The one on my car looks nothing like that at all. Thats my issue.
jdub
Feb 10, 2006
10,730
Valley of the Sun
The one in the picture you posted is correct...they are common across years. You may have a JDM sending unit on your motor. If so, I hope it did not fry your gauge ;)
SUPERSNAIL
Nov 13, 2008
71
Albuquerque N.M.
That would be weak.... :nono: Does anyone have a pic of a jdm one, Im looking for one now.
SUPERSNAIL
Nov 13, 2008
71
Albuquerque N.M.
It looks more like this then the round one i see everywhere else...
Bill UK
90 Supra Turbo 14 psi
Aug 11, 2006
56
UK
That’s my motor 7M-GTE 1990 (UK model) I took that just as I was dropping the engine back in. I can confirm that’s your bog standard Toyota oil sender unit for a UK Supra. PS: The photo in the first posting #1
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
That looks to be a resistive type sending unit. The USDM gage will not work with it and there is a fair chance the gage was toasted by having it in there. To check remove the wire from the sending unit and ground it, but only as long as it takes to see the gage move. Do not leave it grounded longer than it takes the gage to reach maximum. If the gage checks out install the correct sender and hope for the best...
SUPERSNAIL
Nov 13, 2008
71
Albuquerque N.M.
Thanks for all the help guys ill take that pos out and hope the cluster is ok, If not ill be stalking the FS thread for more parts.
