Where is the Oil pressure sending unit?? I found this pic but I cant seem to locate it on the block can somone please give me the specific location because I need to replace mine.
just like the picture shows, from the under side of the unit. just remove the intake pipe and you should have no problem reaching down from the top to do it. It shouldn't be that tight cause it is a taper thread and will only take a little bit of work with the wrench and will unthread the rest of the way by hand. the same goes for putting it back in. once you have threaded it in by hand as far as you can get it, you usually only have to go about 1/2 a turn or so with a wrench to seal it. if it leaks, just go a little bit more. remember, they are tapered threads so they dont have to be that tight. just for info, the hex size is 14mm
I ended up replacing the unit but my guage still dont work so I banged on the guage and it would rise a half inch and then go back down, guess its my guage.
