Oil Pressure sending unit/2j Fuel Rail
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
I have 2 quick questions.
first, where can I find the oil pressure sending unit on my soarer 1j, and can I un plug it without throwing a code or anything, because I have an aftermarket gauge that I would like to use.
Second, I have a 2jz fuel rail and injectors to use. Can i use the entire rail with injectors, or do I have to swap over the 550's into the 1J rail?
thanks,
Trevor
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
thanks,
Trevor
swap into 1j rail.
the oil pressure port is behind the A/c compressor. no codes the oil pressure just goes to the gauge
Spaniard
524
La pearla PR
I just put the oil gauge sending unit on and think it's slow to react. i remember the oil pressure gauge on my 7M reacting quickly. Any thoughts on this?
tlo86
Jul 24, 2005
3,914
Colorado
stock gauges are not known for their quickness. aftermarket units usually are - im going for an aftermarket one when i can the stocker is pretty slow
