Oil Pressure sender threading?
What are the 2 threads Grim?
All of the 7M's I've had through here have been 1/8 bsp in each of the 3 pressure ports.
I end up tapping the middle one to 1/8 NPT so I can use my AN fitting.
JT87NA
SLC, UT
I have a set of Braided Stainless steel oil lines for a CT-26. They are leftover from my 1/2 NA-T build, the return line has a slight indentation but it should be fine. I will sell them for $60.00 shipped if you are interested.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I've no idea what the two threads are, actually. I do, however, know that the oil pressure sender that came on my first block will not thread into the hole on my second one, as it is too large. It looks like a stock sensor, but who knows?
JustAnotherVictim
Do you have some pics and what's the line diameter?
I think it was one of your threads I saw this method on SF
