oil pressure sender help
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
Ok well I swap my working US pressure sender to my jdm block since the jdm one would fry your guage, well I guess mines was dropped on the floor or something because its not working now and now I have zero oil pressure being displayed on my guage. The needle does not move at all when I start the car.
I just ordered a new aftermarket guage and a new oil pressure sender from driftmotion, How hard is it to change the sender while the motor is in the car?
Looks like it would be hard to go too.
Any tips?
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
have you verified that its even hooked up properly? just because the little cover is on doesnt mean that the sender is on the little connector.
and its a bitch to do...
queenskid926
Jul 27, 2007
1,112
New York City
yea its on correctly, and there shouldnt be a short in the wiring but ill just swap in a new one for insurance, any tips on getting the job done?
queenskid926
Jul 27, 2007
1,112
New York City
grimreaper;1217138 said:
might want to make sure there is in fact oil pressure :)
well its no knocking lol and isnt the stock oil cooler operates on a pressure relief spring once it reaches a certain pressure? and on startup the pressure usually spikes up correct? well i have a small oil leaks on the return line bug that only leaks when the car is first started, when the oil pressure spikes up and flows oil thru the oil cooler. so im positive that there is pressure. Speaking off i gotta tighten that nite and fix that leak today lol, but the only other way of checking to see if the car has oil pressure is taking the oil presser sender off anyway correct?
