Oil Pressure, I took my car to Toyota for a timing problem, it was fixed and the tech mentioned a Low Low Oil Pressure, I Have a Canadian Supra, So my Pressure Isnt Measured in PSI it has a KG/cm2 measurment, now at cold idle the gague hits 2 kg/cm2 and at idle and driving it doesnt move more then a few hairs off zero, it does rise slowly but never hit close to 2 kg/cm2 during normal operation, if someone oculd tell me what proper pressure should be at idle and or at a rpm, i plan on getting a mechanical pressure gague to test block pressure but that will be in PSI. so if anyone can help that would be awsome, i dont want another rod knock... :icon_evil
thanks guys
thanks guys
