Just rebuilt. TRSM specs are 4.3 psi @ 650 RPM and 36-71 psi @ 3000 RPM
Readings are ~8 psi @ 900 RPM and ~20 psi @ 2000 RPM+
During the rebuild I shimmed the oil pressure relief valve 7mm so pressure should be excellent. I checked the oil pump clearances and so did the machine shop. I spun/tested the oil pump. I checked the oil filter mount relief valve. I'm running Castrol SynTec 10w30. I did not replace the rings but did install Clevite bearings and reinstalled the mhg, cleaned and copper coated. I used ARP with the ARP engineers direct spec for the 7MGTE of 110 ft-lbs with 30w oil for lube (I stopped at 105 cause I couldn't hold my breath any longer being afraid they were going to strip). A couple cam end journals are scoured but the same as before the build and pressure was higher.
I am going to check my oil pressure sensor, but I did that before with a gauge and air pressure, so I don't think it is just the sensor. Level is full. No bad sounds. Vacuum is good. No oil leaks.
Any ideas?
Any ideas?
