W
womenslider
Guest
Hi again guys wondering if anyone can shed some light on this for me
just rebuilt my engine and was wondering what the oil pressure should be???
as mine seems on the low side considering i have installed a new oil pump.
on idle its sitting on the first mark and seems to make its way up to about 30ish when the revs are increased to around 3000 but havent been able to get exact figures yet as i only finished installing it last night and im not using an oil pressure tester im relying on the supras guage(not sure how accurate they are).
The oil pump was a toga unit apparently high volume and i used their hp bearings in the rods and mains.engine dosent seem to be knocking but i didnt want to run it for to long incase there was an oil feed problem.please note i have quite a lot of experience in rebuilding engines so i measured everything and kept everything as clean as possible
Any ideas???? :1zhelp:
