Oil Pressure at Idle
89Turbo
804
Portland
i am getting my Supra back from a long 6 month rebuild tomorrow but my mechanic drove it to my work today and wanted to confirm that the oil pressure at idle is supposed to be so low, it's pretty much lookin like its at zero, the manual he has on it say that oil pressure at Idle is 4.3 pounds, just wanna make sure this sounds right and i dont need a new oil pressure switch..
mods after i get one solid answer you can delete this......
PICS COMING SOON
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
normal... tsrm says so.. we have a high volume low pressure system. Nothing to worry about
Edit... link in my below reply
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
What does the pressure rise to at 3000 rpm??? I'm starting to feel better about my oil pressure now seeing all the people saying 6 - 8psi at idle is normal I was sweating because mine is between 12 - 15 at idle when fully warmed up. It also depends what oil your running if your running a very light weight oil (0w40) will see less pressure.
SnowMongoose
150
Bellingham, WA
same here candy, most of the time at idle I'm around/just above 20 on the stock guage.
<disclaimer: I idle at around 1100 most of the time, so grain of salt is required with my numbers>
